M5 EBS: Ergonomic brake - thumb levers?
Forum Name: Wanted
Forum Description: You need something? Ask for it here
URL: https://forum.bhpc.org.uk/forum_posts.asp?TID=7866
Printed Date: 27 March 2026 at 4:56am
Topic: M5 EBS: Ergonomic brake - thumb levers?
Posted By: NigelSlee
Subject: M5 EBS: Ergonomic brake - thumb levers?
Date Posted: 29 December 2025 at 11:35am
A bit of a long shot but would anyone have a set of the M5 Ergonomic Brake levers they would like to part with??
Cheers
Nigel
Posted By: melle
Date Posted: 30 December 2025 at 10:03am
Nigel, I wouldn't recommend them, see https://forum.bhpc.org.uk/m5-ebs-brake-levers-wanted_topic7519_post69970.html?KW=#69970" rel="nofollow - here for my experience with them.
Optima Stinger | 2x Baron
Date Posted: 30 December 2025 at 6:33pm
Ah thanks Melle. I should have done a search and found your post - very helpful. Have twist grip gears so the EBS looked a good option especially as attaching on the main centre bar rather than the hand tubes.  The shifters rather tired too. Looking at all options. Want to make sure I can stop!
Nigel
m5 bars
Date Posted: 30 December 2025 at 6:36pm
Mirror looks good - what is it?
Posted By: melle
Date Posted: 30 December 2025 at 6:46pm
One of my Barons has twist shifters and bar end brake levers, works a treat:
Mirror is 80mm Busch + Müller Cycle Star, I have them on all my recumbents.
Date Posted: 30 December 2025 at 9:14pm
Thanks! N
Date Posted: 30 December 2025 at 9:21pm
I've got some fairly old XT combined two-finger brake levers / trigger shifters on mine.  Bit of a tight bend in the cables, but it shifts well enough and it's not like you want the rear brake to be too grabby anyway.  (I'm not a fan of twist grip shifters.)
I have a pair of the smaller Cyclestar mirrors, which - secured with an additional cable-tie to the top of the brake cables - sit neatly somewhere above my knuckes and can just about see over the tailbox.  They're excellent mirrors, though the last 80mm one I bought for my Streetmachine has a bad case of droop.
Date Posted: 30 December 2025 at 10:16pm
Thanks for your input Kim. I think I'll try Melle's suggestion as a starting point as I see SJS have some in stock. Not tried twist shifters before so that will be interesting. Mirrors can wait a bit until I've got brakes sorted.
Posted By: melle
Date Posted: 31 December 2025 at 4:35pm
Correction: I wrote 80mm, but the mirrors I use are the small (60mm) variant. The one on my Stinger also needs a cable tie; I guess the ones with the shorter stalk won't have the droop-issue.
Date Posted: 31 December 2025 at 6:18pm
You might think that, and it was certainly how it worked in the past (longer stem mirrors needed the handlebar clamp done up quite tight to avoid the whole arm drooping).  But the lastest one is loose at the ball-in-socket joint on the back of the mirror, so the stalk stays put but the mirror ends up drooping.  No adjustment there.  Poor quality control, I expect.  I'd have sent it back to the retailer, but I bought it as a spare and didn't discover the problem until I fitted it much later.
Posted By: melle
Date Posted: 06 January 2026 at 12:02pm
Never had an issue with them at the mirror end, it was always the handlebar clamp that was the problem.
