Disk and drum brakes.
URL: https://forum.bhpc.org.uk/forum_posts.asp?TID=7401
Printed Date: 27 March 2026 at 1:05am Software Version: Web Wiz Forums 12.07 - https://www.webwizforums.com
Topic: Disk and drum brakes.
Posted By: mark aldridge
Subject: Disk and drum brakes.
Date Posted: 04 June 2022 at 8:07am
I am getting a bit sick and tired of squeaking and rough braking of my disk brakes. Has anyone replaced disk brakes with drum brakes on a trike. How practical is it. I am up for machining backing plates or brackets if needed.
Date Posted: 04 June 2022 at 3:10pm
Which trike is it as ICE can supply both on some models so maybe off the shelf replacement, or help with components.
Date Posted: 05 June 2022 at 11:53am
ICE recommend choosing drums if you want low maintenance trouble free operation, also the best aerodynamics. They can supply all the parts if it's one of their trikes. They are very knowledgeable and helpful if you phone or email them.
All the best. Roy
Date Posted: 05 June 2022 at 1:09pm
As a matter of interest, all the Velomobiles I've seen have had drum brakes.
All the best. Roy
Date Posted: 06 June 2022 at 9:22pm
It is a Carbontrike. I will be taking the wheels off tomorrow to see what is possible. It is a magnificent trike with a very compliant ride and 100% bombproof mudguards which shrug off the worst weather. The only downfall are the b....y disk brakes. Is there anyone out there who could send me some photos of the ICE backing plate so I can see how it is mounted to the cross beam. Thanks Mark
Date Posted: 07 June 2022 at 7:44am
I would think all the info you need is available here: https://www.sturmey-archer.com/en/products/detail/xl-fd" rel="nofollow - https://www.sturmey-archer.com/en/products/detail/xl-fd
Date Posted: 08 June 2022 at 12:15pm
Ginkgo have a better selection that would suit your trike better. Including nice black ones with shorter restraining arms. http://shop.ginkgo-veloteile.de/en/Wheel-Accessories/Drum-Brakes/" rel="nofollow - http://shop.ginkgo-veloteile.de/en/Wheel-Accessories/Drum-Brakes/
The black ones are here. http://shop.ginkgo-veloteile.de/en/Wheel-Accessories/Drum-Brakes/air-cooled-drum-brakes.html?force_sid=tjnd3r85lt609r34fp0bg01oev" rel="nofollow - http://shop.ginkgo-veloteile.de/en/Wheel-Accessories/Drum-Brakes/air-cooled-drum-brakes.html?force_sid=tjnd3r85lt609r34fp0bg01oev
Note the short arm backing plates are sold separately.
All the best. Roy
Posted By: stormbird
Date Posted: 31 July 2022 at 6:30pm
Mark
You need these :- http://www.sturmey-archer.com/en/products/sd-hubs" rel="nofollow - http://www.sturmey-archer.com/en/products/sd-hubs
These are called Side Drum brakes or SD , they come in:- both left and right versions 70mm & 90mm sizes. and either M12 axle or a Q/R mounting.
At a push the axle can simply be a M12 bolt and a lock nut
So it would help if your current wheels have M12 axles and then you need some sort of pin or bolt to anchor the black anti rotation plate.
This is the back of my Python Delta however it shows how they can be mounted [ eventually ]
https://www.atomiczombie.com/forum/threads/my-life-with-python-trikes-mk1-mk1-5-mk2.33/page-63#post-14841" rel="nofollow - https://www.atomiczombie.com/forum/threads/my-life-with-python-trikes-mk1-mk1-5-mk2.33/page-63#post-14841
Sorry the site won't make a link of this you will have to copy and paste.
Paul
Date Posted: 31 July 2022 at 8:19pm
stormbird wrote:
Mark
Paul |
Hi Paul. The only problem is that his is a carbon fibre trike so it will need a bit more carbon to mount it. It's not as straight forward mounting parts onto carbon fibre as you might think. Needs to be done by someone who knows how the stresses work in carbon fibre materials.
All the best. Roy
Date Posted: 31 July 2022 at 9:39pm
All the best. Roy |
Hmm even a carbon trike must have a metal axle ?
The poster asked how ICE mount the back plates ? i though all ICE trikes were steel ?
the first link was for the wrong SA hub brakes they had through axles.
SJS sell the parts you need however they are not sold either as complete wheels or a ' kit of parts '
You need to know what you want , so:- 1 x left back plate [ 70mm or 90mm ] 1 x right back plate [ 70mm or 90mm ] 2 x hub shells [ 70mm or 90mm ] 2 x cable adjusters [ the long ones ] 2 x cable end clamps [ fit the actuating arm saddle ]
spokes and rims
back plates could be Q/R then you also need 2 x Q/R spindles
Paul
Date Posted: 31 July 2022 at 9:57pm
Other option is to get decent calipers. The TRP Spyke mechanical disc calipers are good and easy to fit. For hydraulics, you can't beat Hope. Would be simpler and cheaper than fitting drums maybe?
------------- Right Time - Right Place - Wrong Speed
Date Posted: 01 August 2022 at 9:46am
Hi Paul When I suggested he contacted ICE and asked for advice he said it was a Carbon trike. http://www.carbontrikes.com/eng/index.html" rel="nofollow - http://www.carbontrikes.com/eng/index.html
"It is a Carbontrike. I will be taking the wheels off tomorrow to see what is possible. It is a magnificent trike with a very compliant ride and 100% bombproof mudguards which shrug off the worst weather.The only downfall are the b....y disk brakes. Is there anyone out there who could send me some photos of the ICE backing plate so I can see how it is mounted to the cross beam. Thanks Mark"
I'm guessing he is planning to replicate ICE's solution in carbon fibre. The stresses will be very high on the backing plate so it needs someone who knows how the stresses in carbon fibre relate to what he wants to do. Otherwise he risks a very expensive failure of his cross beam. Personally I'd live with the disk brakes because that is what the trike is designed for.
All the best. Roy
Date Posted: 01 August 2022 at 10:23am
All I can tell Mark is that ICE mount their disk brakes on a very substantial plate about 15 mm thick. They mount their drum brake retaining plate on a very substantial irregular shaped casting. Mine is on a suspension model though so a non suspension model may be different. All the best. Roy
Date Posted: 01 August 2022 at 10:46am
Looking at the photos of the Carbon Trikes I notice that they use a similar plate to ICE for mounting their disk brake. If you could mount the drum backing plate to that it would work without any extra stress on the carbon fibre I would have thought. Just my opinion though and I take no responsibility if the trike breaks. My After 7 drum brake is mounted on an aluminium plate and it has suspension and no rear covering, for better cooling. All the best. Roy
Date Posted: 01 August 2022 at 3:41pm
My thoughts it is already a ' strong point ' on the trike.
However of more concern is what is the current axle diameter ?
SA hubs like a M12 bolt or their own M12 Q/R skewer.
Paul
Date Posted: 01 August 2022 at 8:58pm
Paul
| Hi Paul, they make their own lightweight hubs http://www.carbontrikes.com/eng/news.html" rel="nofollow - http://www.carbontrikes.com/eng/news.html so I think the only way to find out is to ask Mike or contact them or go to their stand at SPEZI. They won't be using standard axles for sure. The weight would be too much. Might be a standard diameter though to fit the ceramic bearings they are using.
All the best Roy
