Windcheetah Help
Forum Name: Any Other Business
Forum Description: Anything not covered by the other forums: social, humour, goat-keeping, etc
URL: https://forum.bhpc.org.uk/forum_posts.asp?TID=6638
Printed Date: 27 March 2026 at 4:56am
Topic: Windcheetah Help
Posted By: skypilot
Subject: Windcheetah Help
Date Posted: 22 January 2018 at 2:11pm
Hello All,
I've located and made initial contact with the seller of an older Windcheetah. I've been searching for quite sometime. It's difficult to find one over here in general, add the proper size and being close enough to pick up.
I had a quick text with the seller and the size does seem to be good, we're the same height at least.
In the for sale ad, he noted the manufacturer  as "The Seat of the Pants Company".  From what I've been able to find out they built for Mike Burrows, before Bob Dixon bought them.  Is this correct?  I'm waiting for the seller to get to me the SN, he was not home at the time. Pity I could probably see it in the pictures but the tiller is covering the plate.
It's not close enough for me to just pop over and inspect and try it, it will be an 8 hour round trip. It appears to be in pretty good condition in the pictures, other then some rust on the BB spindle.
Any help as to what to look for when I do get to see it and perhaps some help on identifying it?
I've included a link to the for sale ad with pictures
https://philadelphia.craigslist.org/bik/d/for-sale/6428698284.html
Best Regards
Jim Smith
Upstate NY
Posted By: skypilot
Date Posted: 22 January 2018 at 5:33pm
Serial number 358
Date Posted: 22 January 2018 at 8:00pm
I'm fairly sure Seat of the Pants was what Bob Dixon's company was called when he was selling a wider range than just Windcheetahs.
Posted By: skypilot
Date Posted: 22 January 2018 at 9:16pm
 You're right. I found a screen capture on the Wayback Machine archives from 1999. It does state there Mike Burrows designer and Robert Dixon, Seat of the Pants.  There's links to Seat of the Pants there also.
Thanks.
Posted By: D.TEK
Date Posted: 22 January 2018 at 9:36pm
Windcheetahs are great fun and just like a race horse from Newmarket
They go like the wind can be scatty as hell and be prepared for high vet bills !
So could make a wonderfull addition to your recumbent stable .
Its a seat of the pants built by Bob Dixon
With the gas pipe joint style Y section handle bar control mounting
Note the Moulton wheel size which is somewhat restricted on tyre choice
and novice riders can kill Moulton rubber in less than 400 miles .
Most newbie owners  go mad doing doughnuts and tighter turns ( "is that a front wheel in the air " )
Check the underside of the main frame for rubs and scuffs and off-road frame damage
Kingpins can wear and steering joints are race weight and can also wear .
Brakes are " Bomb proof " ......sorry forgot your over the Atlantic
bad bad bad common British phrase  *spellcheck suggests replace with "  very durable "!
Look to see if the chain has jumped off and attempted to saw the cross tube on the underside .
If the nylon chain pulley appears to have cogs or teeth ...its knacked ...
The four rubber bonded seat mounts can degrade ....or break in half .
Easy fix with British MINI car  exhaust mounts (imperial thread )
Most parts are replaceable if and when required .
All the main castings are glue bonded ....some early Dixon built WC failed due to poor machining
and often Bob blamed the glue ....so look out for re-glue repairs and any strange roll pins or bolts or screws and repainted castings .
If you require further advice ...just ask
I sold them brand new in the 90's until Bob Dixon decide to sell factory direct .
Since then I have traded in used models and provided owners with another source of spares and parts
Regards Kevin D
D.TEK HPVS purveyors of recumbent trikes and cycles
Posted By: skypilot
Date Posted: 23 January 2018 at 2:09pm
Regards Kevin D
Thanks Kevin!  My first thought was to PM you:-)
So it has the old Moulton size wheels then?  I asked the seller, he was at work and wasn't sure, he's supposed to get back to me.  I thought it strange he doesn't know something like that.
I'm going to have to make room in the garage for it, probably the TNT will have to go.  Micro, GTX, and the S are keepers.
Thanks again for your help.
PS "Bomb proof" = "Bullet proof" over here.
Regards
Jim
