Square tube, or round?
URL: https://forum.bhpc.org.uk/forum_posts.asp?TID=5255
Topic: Square tube, or round?
Posted By: DavidAger
Subject: Square tube, or round?
Date Posted: 20 February 2016 at 3:16pm
Hi all,
Just want to say hello.
I'm a newbe to this forum,club an HPVS, or any forums come to that.
I don't have an HPV as yet but hoping to build one!
I've found some plans on AtomicZombie, the tomahawk (SWB low racer)looks good to me except they use square box tube and I would prefer round.
I'm aware that it will be more difficult, but I think I can cope with that.
My main problem is if I use round tube which would be the best size to replace the 1.5mm box tube?
Any ideas please?
Thanks for reading this, and might see you at the first meet, looking for ideas.
David Ager AKA David
He who has choice has torment!
Date Posted: 20 February 2016 at 5:17pm
Welcome David!
There are quite a few builders on here so I'm sure somebody that knows what they are talking about will be along soon... Big smile
In the meantime it might be worth grabbing a copy of SYWTB, our guide, the latest edition of which was put together by Mike Burrows.
http://shop.bhpc.org.uk/so-you-want-to-build-an-hpv" rel="nofollow - http://shop.bhpc.org.uk/so-you-want-to-build-an-hpv
Date Posted: 20 February 2016 at 5:29pm
Thank you for the welcome Alan, and the info, I'll look forward to any reply.
David
Date Posted: 20 February 2016 at 6:19pm
Hi David,
As you are probably aware, tube is stiffer in bending and torsion than square box-section for the same weight, but box-section is easier to mark out, mitre and jig, which is probably why Atomic Zombie use it.
It is difficult to give advice without seeing the design you plan to build. If you post a link then we can have a look. All I can say at this stage is that you will make a lighter bike if you can find 18 swg (1.2mm), which is not always easy in the larger diameters but possible and worth the effort. I've used 1 3/4" diameter by 18 swg ERW. My first bike was 1 1/2" x 18 swg box, which worked fine for a short wheelbase bike.
Date Posted: 20 February 2016 at 6:29pm
Ah, okay, found the Tomahawk. I'd advise building a 'straight-tube' framed bike as a first project, they are much easier to make, lighter and easier to ride, not to mention less daunting to ride in traffic.
A 'Z-frame', like the Tomahawk, has a lot more joints and are much harder to weld straight. I have built a number similar machine with round tube (mostly with 1 3/4 diameter x 20 swg T45 but that is very expensive stuff!). I would certainly recommend adding a gusset around the head-tube to the Tomahawk design as this stiffens the frame considerably.
PS: You can see some of my pre-2007 bikes here:  http://www.facebook.com/media/set/?set=a.1427371618750.56189.1666613055&type=1&l=ef1066e86a" rel="nofollow - https://www.facebook.com/media/set/?set=a.1427371618750.56189.1666613055&type=1&l=ef1066e86a
Date Posted: 20 February 2016 at 6:46pm
Have you ridden any recumbent bikes so far David?
As Geoff says lowracers are a little more tricky to get on with. Harder to get started on hills, a little awkward at junctions. I wouldn't ride one in heavy traffic myself to be honest.
Something like the Atomic Zombie Spirit would be easier to ride while getting the hang of it.. http://www.atomiczombie.com/Spirit%20Short%20Wheelbase%20Racing%20Bike.aspx" rel="nofollow - http://www.atomiczombie.com/Spirit%20Short%20Wheelbase%20Racing%20Bike.aspx
Date Posted: 20 February 2016 at 6:52pm
Thanks Geoff,
I've included the link but must admit I do wonder if it's a bit low for traffic.
I can get 50mm x 1.2mm erw tube and perhaps other sizes but I'm still in thinking stage at the moment so can do with as much info as poss.
Not looked at your bikes yet but I will shortly.
http://www.atomiczombie.com/TomaHawk%20Short%20Wheelbase%20Recumbent%20Lowracer.aspx
David
Date Posted: 20 February 2016 at 6:59pm
2" x 18 swg wil make a very stiff frame - my 3rd to 5th bikes used either 50mm x 1mm CDS or 2" x 20 swg T45 (all straight tube designs), but this is very difficult to get now. The 1 3/4" just saves a bit of weight and is stiff enough for most applications.
The other thing that concerns me about the Tomahawk is the position of the chain pulleys up by the head tube - they look like trouser-eaters to me :-) . Note in the video how he is riding bow-legged.
Date Posted: 20 February 2016 at 7:06pm
No I've not ridden one yet. I liked the look of the low racers, perhaps I should leave them for the future as Geoff advised.
I can probably make one from just photos so I'm no restricted to plans.I'll have a look at the links that you and Geoff gave me and go from there, so, if you see some one walking around with a tape measure and pad at Hillingdon in April you'll know it's me, if that's allowed of course.
Date Posted: 20 February 2016 at 7:11pm
Happy to send you scale drawings of some of my bikes if that helps David. I even have CAD models of the more recent ones. The difficult thing to get right is chain runs and chain management in my experience. This is useful link -  http://www.framebuilding.com/" rel="nofollow - http://www.framebuilding.com/ - Peter is a very helpful and efficient retailer.
Allowed?? It's encouraged!! Big smile
How tall are you??
Date Posted: 20 February 2016 at 7:13pm
Ouch, that could be nasty, perhaps a front wheel drive SWB, that way it will have a shorter chain which must be better, if only for cleaning. 1 3/4" tube sounds good to me.
I'm getting there, I've learnt more in the last half hour than the last week.
Thanks chaps.
Date Posted: 20 February 2016 at 7:14pm
5'10".
Date Posted: 20 February 2016 at 7:17pm
I've just realised I can reply to individuals, sorry if sent a teply to the wrong person?
Date Posted: 20 February 2016 at 7:18pm
Probably a bit on the tall side as I'm a shorta**e... but may be worth having a play on my Kingcycle as you're fairly local...
Date Posted: 20 February 2016 at 7:20pm
Front wheel drive has it's appeal (I managed one with front suspension as well!) but chain management is even more difficult as is stopping it eating your trousers. RWD is easier to engineer.
You are posting correctly. Everyone can see the conversation and chip in.
Date Posted: 20 February 2016 at 7:25pm
I have a very interesting front wheel drive machine here (from an engineering point of view)... I'll hopefully have it at Hillingdon.
https://www.youtube.com/watch?v=S9bo2MOyXNA" rel="nofollow - https://www.youtube.com/watch?v=S9bo2MOyXNA
Date Posted: 20 February 2016 at 7:31pm
Thank Geoff, plans would be good if you don't mind.
I've looked at your collection, wow they're lovely. I didn't realise so much went into it.
It seems quite obvious I need to start small. I only had in tensions of building one, not any more.
I've already got four two wheeled bike's at the moment so I'll have to find a bit more room somewhere.
Kitchen?
Date Posted: 20 February 2016 at 7:41pm
Yeah, I've got two in the dining room at the moment - the cleaner ones, so that's okay ;-)
What format can you deal with for the plans? PDF, DXF or just JPEG? It would be easier to send by email. I'll private message you my address.
Posted By: demondunk
Date Posted: 21 February 2016 at 7:45pm
We all have to start small , but it becomes very addictive. Built my recumbent lowracer. This is the best place for advice and everybody here are fantastic.
Date Posted: 21 February 2016 at 8:18pm
He's right you know, we are... Big smile
Date Posted: 21 February 2016 at 8:24pm
I can see that,I'm glad to be on board.
Date Posted: 21 February 2016 at 8:38pm
Posted By: Karl
Date Posted: 22 February 2016 at 10:17am
David, Welcome,
Have you considered other materials?
Barney built a very nice wooden machine that was surprisingly nice to ride (no reflection on his building ability btw)
Another option is to go skip diving for old bikes, as most of the leg work is done for you, all you need to do is repurpose them, break out angle grinder and a welder.
http://ceeway.com" rel="nofollow - http://ceeway.com  is a good place for cycle frame building materials
Shame you're not oop North you could have had a ride on some of mine.
Karl
Date Posted: 22 February 2016 at 1:54pm
Thanks Karl
Wood is a good idea, but metal is easier for me as i already have the necessary,perhaps in the future.
I have skip diving (I like that phrase) on my list as I've seen a few nice photos.
I hope to go to Hillingdon in April, perhaps see you there, although it is "darn sowf"
