Kincycle Suspension Fork
URL: https://forum.bhpc.org.uk/forum_posts.asp?TID=5112
Printed Date: 27 March 2026 at 3:18am
Topic: Kincycle Suspension Fork
Subject: Kincycle Suspension Fork
Date Posted: 05 April 2015 at 12:37pm
Does anybody have any tips for removing a Kingcycle suspension fork.
Bruvver Dave has tried hitting it to no avail.
Do we need a bigger hammer or a bigger bruvver?
Posted By: Andy TS
Date Posted: 05 April 2015 at 7:26pm
If stuck try penetration spray and leave over night. Failing that I once removed a damage steerer by cutting from the inside out until it was loose enough to slip out of its own accord.
Allewedder A2, Broken Optima Baron Lowracer
Posted By: Karl
Date Posted: 05 April 2015 at 7:28pm
Gentle heat.. start with a couple of kettle full of freshly boiled water.
Then on to the heat gun set on low.
Dont over heat though otherwise it will turn to mush.
Karl
Date Posted: 05 April 2015 at 7:30pm
Thanks Andy.
I think he's already given it a going over with penetrating spray so we may be heading towards a hacksaw. Nothing else holding the suspension fork as far as you know? It's a strange setup... We have a standard fork to replace it so wrecking the fork wouldn't be the end of the world.
Date Posted: 05 April 2015 at 7:32pm
Thanks Karl.
It certainly doesn't seem keen to budge by fair means.
