Woody the Kmx
URL: https://forum.bhpc.org.uk/forum_posts.asp?TID=5090
Topic: Woody the Kmx
Posted By: Andy TS
Subject: Woody the Kmx
Date Posted: 17 February 2015 at 5:17pm
Thanks to John Lucien I have inherited a KMX trike of some description and although fun to ride is well - a bit slow - compared to my Baron.
Its main advantage over the baron is it doesnt fall over and on wet roads fully loaded with work kit in heavy traffic the baron can be a bit of a handful. Once on clear roads its off but wet drain covers still fill me with dread.
To that end i have taken the bold and somewhat foolish step of building a body for it.
Criteria:
1) The body is of cheap material so if I balls it up hey ho no problem
2) Does not require specialist tooling and can be made in a garage
3) is easy to work and available materials
So having seen Sam Knights Black pig and a couple of plywood velomobiles on tinterwap thats what i am doing.
After much standing in the garage and staring i have made it as far as cutting out the base and am in the process of looking at supports and mounts to the frame before the hard work of attaching the sides and top begins.
But one problem at a time.
Hardest bit was working out the wheel cutouts and although a little to big (can fil gaps later) am happy with the outcome.
Now how to get some pictures up
Allewedder A2, Broken Optima Baron Lowracer
Posted By: Andy TS
Date Posted: 17 February 2015 at 5:21pm
Hurrumph - cant seem to add photos :-(
Date Posted: 17 February 2015 at 5:24pm
Have you clicked the "Full Reply Editor" (arrow pointing up and to the right) at the top of the reply box?
Date Posted: 17 February 2015 at 5:36pm
Ooooh - You're right - I can't upload pictures either... We'll kick the hamster that runs round in the little wheel that powers the forum...
By the way, Bruvver Dave has just built a plywood tailbox for his Kingcycle which looks very nice.
I would upload a picture but...
Date Posted: 17 February 2015 at 5:42pm
Hmmmm...
Just had a quick look and the settings seem ok - As a member of the BHPC Member group you should be able to post an image as long as it's under 200K and 600x600
I'll escalate this to somebody that knows what they are doing...
Date Posted: 17 February 2015 at 10:20pm
Hmm... looks like one for the Man Who Looks After the Garden. I'll ask him when he comes back from his lunch.
Bill (or was it Ben?)
Date Posted: 18 February 2015 at 10:00am
The problem of uploading files and images has now been fixed (by http://en.wikipedia.org/wiki/Man_Who_Worked_in_the_Garden" rel="nofollow - The Man Who Works in the Garden not I, the Hamster in the Wheel)
Posted By: Wyndrake
Date Posted: 18 February 2015 at 10:58am
Ah! Adrian....you remind me of the little known fact, that in January 1955, The Man who Worked in the Garden, fed up with his downtrodden life and all that Oddle Poddle, fell in love and eloped to Cloud Nine with the luscious Little Weed.
Unknown to them both, the ageing Muffin the Mule, had carried a burning pash for Little Weed for yonks. It was the news of this elopement, that sent Muffin into the deep depression that caused him to commit suicide, by diving off Annette's piano and breaking his Main String on impact. I still recall the look of anguish on Muffin's face as he fell silently ......
If only The Man who Worked in the Garden had taken up recumbent riding, rather than juggling earth worms, none of this would have happened.
Phew! Back on topic - just! Big smile
Posted By: Andy TS
Date Posted: 18 February 2015 at 11:19am
Where it all started with the KMX
Big Chainring
Starting to mark out the frame points
Drawing out the edges
Cut out
Wheel Wells - back was easy front not so much
Next up is the shape of the nose and mounting of the base to the frame - luckily there are many mounting points and a flat bottom on the trike allows for easy bolting too.
Posted By: tincanracer
Date Posted: 18 February 2015 at 11:51am
I would be interested in seeing these piccys please Alan when you and the tinterweb have a moment.
Stuart
Laid Back in Spirit
Date Posted: 18 February 2015 at 12:05pm
Originally posted by Wyndrake Wyndrake wrote:
...in January 1955, The Man who Worked in the Garden, fed up with his downtrodden life and all that Oddle Poddle, fell in love and eloped to Cloud Nine with the luscious Little Weed.
Alan - have you ever wondered what it was they were sprinkling on your cornflakes? Confused
Date Posted: 18 February 2015 at 1:32pm
Glad it's all sorted ... Thanks Andrew. Thumbs Up
I haven't got a picture of Dave's wooden tailbox here unfortunately - I'll have to grab one when I see him...
Date Posted: 18 February 2015 at 9:49pm
Looking good so far Andy. Might there be an article for the mag in it?
Posted By: Andy TS
Date Posted: 18 February 2015 at 11:52pm
Geoff- certainly up for an article (if I ever get near finished).
Date Posted: 19 February 2015 at 7:52am
Nice start, but please don't put a big air scoop on it!
Posted By: Andy TS
Date Posted: 19 February 2015 at 11:36am
Have left Sam out of the design decisions to date though will be involved in the later swearing and hitting things stage as i do the sides.
Sam - Black pig needs a new skirt too and i have an idea :-)
Posted By: Andy TS
Date Posted: 20 February 2015 at 10:22am
Done a bit of work on a wood seat as the original KMX one is for masochists only.
Been good as get to practice joining the wood and using my optima seat as a template i know it should be pretty comfy.
Have stuck the wood together on the front side with epoxy and am waiting to harden before lifting and repeating on the back and filling any gaps with epoxy/sawdust mix.
once solid i will cut to seat shape, sand and glass to finish off.
Date Posted: 20 February 2015 at 2:52pm
Epoxy?  I take it your garage is heated, or is that your living room? Wink
I would have thought it was too cold for epoxy to harden at the moment.
Posted By: Andy TS
Date Posted: 20 February 2015 at 5:05pm
Quite warm in my garage at the mo. And seemed to harden ok.
Few weeks back it was freezing but last night was short sleeves.
May stick a little heater in if it gets cold again.
Date Posted: 20 February 2015 at 5:12pm
It does need to cure properly, preferably at elevated temperatures. It may seem okay until you leave it in the sun, when it may become like toffee (but not as edible).
Posted By: Andy TS
Date Posted: 20 February 2015 at 5:31pm
Good to know. Will make my garage a lovely little suana 😄
Date Posted: 22 February 2015 at 10:51pm
Hi Andy
Looking at the photo of the rear wheel slot - make sure to leave enough gap round the rubber tyres that allows for wheel flex.
If the tyre is close to the fairing then if going round a corner e.g. at 30mph the wheel flexes and subsequent tyre rub can result in an interesting explosion that results in very exciting sideways travel
You may also have seen this beauty of a wooden velo in this blog:
https://velomobiel.wordpress.com/" rel="nofollow - https://velomobiel.wordpress.com/
Good luck with the building.
Regards
Brian.
Date Posted: 23 February 2015 at 8:02pm
We won't ask how you know this Brian :-)
Date Posted: 24 February 2015 at 9:17am
I concur with Brian having departed backwards into the undergrowth at 30 mph at Lancaster for that very same reason.  You don't get a second chance when it happens!
I made the wheel slot very wide, then "duck taped" it closed so the tape nearly brushed the tyre, it's amazing when the tape wears as to how much rear wheel deflection there is.
Posted By: Andy TS
Date Posted: 24 February 2015 at 10:55am
Good to know. There is a fair amount of clearance already but any estimates of how much needed
Date Posted: 24 February 2015 at 11:04am
nope, it depends on how flexible "your" rear end is? You could try having somebody sit in it (same mass and position you will ride in) with the brakes on then push the rear triangle to one side on the rear drop outs, just before the tyre lets go will be the maximum deflection (something break though, not my responsibility).  Not very scientific I know
Date Posted: 24 February 2015 at 4:36pm
What you silly boys need to do is slow down a bit - If you will insist on going round corners at 30 miles per hour then you are going to have problems...
I've never had any problems like that...
Oh, I see...
Posted By: Andy TS
Date Posted: 26 February 2015 at 1:29pm
Pah will crash test dummy testing at reading velodrome once the base is mounted and up and running again ahead of building the bodywork.
Rear end is all kmx so overbuilt steel, doesn't seem to flex and with Alan on the slow down for corners anyway 😄
Date Posted: 26 February 2015 at 2:45pm
Posted By: Andy TS
Date Posted: 18 March 2015 at 1:22pm
Given I now have carbon seat going spare I will line that up and fit to the frame in the next week or two so I can race a naked woody at hillingdon and shakedown the running gear ahead of strapping the body on
