Opportunity for a 'bent
Forum Name: Other non-BHPC events
Forum Description: Events not covered by the above
URL: https://forum.bhpc.org.uk/forum_posts.asp?TID=4938
Printed Date: 27 March 2026 at 4:57am
Topic: Opportunity for a 'bent
Posted By: jdp298
Subject: Opportunity for a 'bent
Date Posted: 31 December 2013 at 3:41pm
I reckon this fella'd do better on a faired recument. Still, props for getting the speed up in the first place.
http://www.channel4.com/programmes/speed-with-guy-martin/videos/all/britains-fastest-cyclist" rel="nofollow - http://www.channel4.com/programmes/speed-with-guy-martin/videos/all/britains-fastest-cyclist
So, 200mph on a bike anyone?
I'll have a beer and money sandwich; hold the bread
Date Posted: 01 January 2014 at 8:21am
A recumbent wouldn't be any faster, be it faired or not when motor paced. It's benefit over a DF bike of reduced wind resistance is nullified. In fact running behind that truck a DF was probably an advantage as the airflow was moving forward so having a large frontal (rear) area was best.
Posted By: Andhar
Date Posted: 06 January 2014 at 12:44pm
This man has done this:
The highest speed ever achieved on a bicycle is 268.831 km/h (166.944 mph) by Fred Rompelberg (Netherlands) behind a wind-shield fitted to a dragster car at Bonneville Salt Flats, Utah, USA on 3 October 1995
Guy's record is an European one.
Andrew Harrington
Posted By: jdp298
Date Posted: 10 January 2014 at 10:33pm
Maybe not the faired bit, but the aerodynamics are that he's in very turbulent air without any obvious stagnation points. So not better DF or bent. But with a bent, you can apply more than your bodyweight, provided your legs are up to it.
Date Posted: 11 January 2014 at 12:22am
You can on a DF too surely?
I don't thing there is any advantage on a bent in that situation...
Posted By: jdp298
Date Posted: 25 January 2014 at 5:46pm
Yes you kind of can on a DF, but it relies on bracing yourself against the handlebar and pulling up on it. It's not that efficient and has to work its way all through the body from the hands to the legs. The bent is more of a pure squat motion braced against your lower back, and therefore more efficient and reliably applied.
Someone should do it on a bent just to make a point.
Date Posted: 25 January 2014 at 5:48pm
Go on then - I'll bring a camera...
Date Posted: 26 January 2014 at 8:48am
I watched the programme again, it was definitely stated that he wasn't in turbulent air he was in air that was moving forwards i.e. being sucked along, ergo a large surface area is best to maximise that effect, just like a sail. A bent would not be able to catch that forward moving air.
