BIG chainrings
Forum Name: Wanted
Forum Description: You need something? Ask for it here
URL: https://forum.bhpc.org.uk/forum_posts.asp?TID=4925
Printed Date: 27 March 2026 at 4:57am
Topic: BIG chainrings
Subject: BIG chainrings
Date Posted: 21 November 2013 at 2:50pm
Hi, I'm after a chain ring, 130 bcd 5 arm, 75 or 80t.
Cheers
Ian
Posted By: BarneyH
Date Posted: 21 November 2013 at 7:19pm
Ian
Raptobike.com component shop and I think their standard as 130mm.
Good luck
Barney
Date Posted: 21 November 2013 at 7:55pm
Cheers Barney, i'll have a look.
Date Posted: 22 November 2013 at 12:13pm
Try http://www.alligt.com/en/chain-rings" rel="nofollow - Alligt in the Netherlands - they do beautiful CNC chainrings up to 80T in 110 and 130mm BCD. They also do chainrings with built-in guards which are great for compliance with BHPC racing rules.
Date Posted: 22 November 2013 at 3:17pm
Hi Ian
I've got a seventy tooth if thats any good for you its 130 bcd shimano type
Jeff.
Date Posted: 22 November 2013 at 4:53pm
Andrew, Alligt had been mentioned to me, they seem to supply Europe with big rings. Them and Dutch Bike bits are the same price, Raptobite sell them with a small increase in price!
Thanks for the offer Jeff, I'll do some calculations (or rather Sheldon Brown will) and PM you.
Posted By: BarneyH
Date Posted: 22 November 2013 at 6:18pm
Ian
If trying to do gear calcs have you tried k gear from the kinetics site, I find it the most user friendly, its free and seems very reliable for all manner of odd set ups..
http://www.kinetics-online.co.uk/parts-accessories/gearing/k-gear-software/" rel="nofollow - http://www.kinetics-online.co.uk/parts-accessories/gearing/k-gear-software/
Date Posted: 22 November 2013 at 7:42pm
Easy to use Barney, but I don't understand gear inches or metres, or rather I can't translate them into speed. Mph/100rpm I can understand and "feel".
Posted By: BarneyH
Date Posted: 24 November 2013 at 10:23am
Ian
I don't really understand what the numbers mean on the road either but what I do is to enter the current ratios I've got on whichever bikes I like and then enter the proposed set up to see how my current ratios compare to the proposed, its just a way of comparing to each other - I'm probably doing this all wrong but who cares, I just get out and ride whenever I can.
Date Posted: 25 November 2013 at 11:42am
This is essentially Sheldon Brown's " http://sheldonbrown.com/gain.html" rel="nofollow - gain ratio " which takes the entire gearing system, including crank length, into account. It relates distance travelled by the pedal to distance travelled along the road, which is the same as your mph/100rpm, only with both sides of the ratio divided by time. Sheldon Brown was a very bright chap.
Personally I find the European system of metres of development (distance travelled per pedal turn) a whole lot more understandable than 'gear inches', the imaginary diameter of some enormous penny-farthing wheel.
Posted By: Yowie
Date Posted: 25 November 2013 at 5:32pm
As Barney says, the way most people get to know and understand what gear inches are is by trial and experimentation.  Looking at your favourite bikes and gears that you actually spend time in is a good method.  Sheldon't Gain Ratio as he calls it is an additional factor relating to crank length, so if you're comparing a 170mm crank road bike with a 150mm crank recumbent, all other things being equal means that the gearing is 170/150 higher on the recumbent.  Aerodynamics of course may affect your consideration of what the gear range should be, but don't go overboard.
Date Posted: 25 November 2013 at 5:48pm
I'm just replicating what is already on Wobbly Bob (80t). I'm hoping to stick a boom and BB in rather than the fragile Z cranks that are too easy to bend, I want to be able to mash it from the line, this will mean I can "grrrrrrr" like Barney then!
On rooting around in the shed I might have stumbled across something which might mean not having to purchase a new ring after all.
Posted By: Wyndrake
Date Posted: 25 November 2013 at 10:40pm
So Yanto, you've got nuclear mice in your shed too ....Big smile
Date Posted: 25 November 2013 at 11:12pm
shush, the technical inspector might be reading!
