  New Posts New Posts RSS Feed - SRAM parts
SRAM parts
stormbird View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stormbird Quote  Post ReplyReply Direct Link To This Post Topic: SRAM parts
    Posted: 08 February 2019 at 7:33pm
Hi there
Anyone know where I can buy a SRAM Dual Drive shift rod ?
This has several other names apparently , it screws down inside the hub and is the part the Click Box clamps around ?
Unable to see any markings on the hub , however it is a 3 x 9 DualDrive [II ?]
farwer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farwer Quote  Post ReplyReply Direct Link To This Post Posted: 08 February 2019 at 9:20pm
I guess it's this one?
https://handbike-ersatzteile.de/stricker-handbikes/ersatzteile/schaltung/1021/dual-drive-schaltstaebchen
I can check how to get it to the UK if you want. From their web site sending abroad doesn't seem straight forward.
Jochen
Post Options Post Options   Thanks (0) Thanks(0)   Quote stormbird Quote  Post ReplyReply Direct Link To This Post Posted: 08 February 2019 at 9:48pm
Hi there
I hope so !
This is from the 2015 Spare parts catalogue:-
However part No 2 lists 3 versions , without explaining if they are in anyway different.
It is on an old Nazca Fiero
At this point ANY will do to try , certainly easier than trying to make one, so yes I would like one.
Edited by stormbird - 08 February 2019 at 9:50pm
Post Options Post Options   Thanks (1) Thanks(1)   Quote farwer Quote  Post ReplyReply Direct Link To This Post Posted: 08 February 2019 at 10:06pm
I once ordered washers and nuts for the DualDrive and it turned out there is a 10mm and a 10.5mm version and I got the wrong one
I will check with the German shop regarding posting.
Post Options Post Options   Thanks (0) Thanks(0)   Quote stormbird Quote  Post ReplyReply Direct Link To This Post Posted: 08 February 2019 at 10:54pm
Farwer
If possible maybe 2 would be a good idea ?
they seem extremely vulnerable hanging out in the wind Ouch
Post Options Post Options   Thanks (0) Thanks(0)   Quote farwer Quote  Post ReplyReply Direct Link To This Post Posted: 08 February 2019 at 10:58pm
Very true.
Post Options Post Options   Thanks (0) Thanks(0)   Quote stormbird Quote  Post ReplyReply Direct Link To This Post Posted: 08 February 2019 at 11:08pm
Farwer
Mine looks like this ?
Picture taken from here :-
No date or model number though.
Same picture on Sheldons site could be dated around 2011 ? [ about 1/3 way down ]
Post Options Post Options   Thanks (0) Thanks(0)   Quote farwer Quote  Post ReplyReply Direct Link To This Post Posted: 08 February 2019 at 11:53pm
Does it say DDI, DD2 or DD3 on the hub?
Post Options Post Options   Thanks (0) Thanks(0)   Quote stormbird Quote  Post ReplyReply Direct Link To This Post Posted: 09 February 2019 at 8:06am
Farwer
At a quick glance no.
However it is down the side of the car [ much to the wife's disgust ] so hard to see much at all and current blowing a gale and raining.
Is there somewhere I need to look ?
I don't really want 9 speed , as I have no parts for that.
Only need the DualDrive [ should it work ] as there is no front mech post.
Post Options Post Options   Thanks (0) Thanks(0)   Quote stormbird Quote  Post ReplyReply Direct Link To This Post Posted: 09 February 2019 at 12:41pm
Farwer
My hub has a blue band on it that has some writing on it saying Sram DualDrive so I assume that makes it a DD ?
My friend has a Sram 3x9 which does not use the click box ? it just has a chain and a black connector ?
Maybe that is easier to find for sale ? and removes the vulnerability of the click box ?
