Sachs/Sram 3x7 hub nice if it was in 20" wheel |
Post Reply |
Author | |
stormbird
BHPC Member Joined: 10 November 2005 Location: United Kingdom Status: Offline Points: 605 |
Posted: 14 March 2020 at 1:52pm |
Anyone have a working Sachs/Sram 3x7 hub preferably in a 20" wheel but loose or different wheel size considered ? No problem if it does not have the shifter's or spokes/rim need attention etc as long as the hub is sound. regards Paul
Velocio
Visitor (new) Joined: 14 September 2017 Location: North East Status: Offline Points: 28 |
Paul - I think I have one of these, a hub that isn't built in to a wheel. No shifter, rest of it may be there. I'll have a look in the bike shed (aka the spare bedroom). Does this forum have a private message function? If you send me your address I could post it. Other question would be what price you have in mind? Dave
Velocio
Philip S
BHPC Member Joined: 16 March 2011 Status: Offline Points: 12 |
Did this get sorted?
Funnily enough, that is exactly what I need as my 3x7 hub has lost the ability to change the hub gear. Many thanks Philip
Velocio
Phillip - yes, I had a spare hub which I've sent to Stormbird.
Velocio
stormbird
Hi there Hub still hear , no progress made in lacing it into a wheel I am afraid. I though these hub's were considered bomb proof and only failures were from the cables ? regards Paul
Philip S
They may be bombproof, but I lost the toggle chain, and none of the bike shops I have tried seem able to reconnect it. I am sure it is the right part as I have bought two identical parts from different sources.
Best wishes with your wheel! Philip |
stormbird
Hi there Did you buy Sachs/Sram chains ? and have not been sold Sturmey Archer chains ? Paul
Philip S
That was my first mistake but I am pretty sure that these are Sachs/SRAm - they certainly aren't the same as Sturmey Archer.
Thanks for the thought!
stormbird
Philip
Ok couple questions ? What do you mean by lost ? Is it possible it snapped leaving some of the thread in the change rod threaded hole ? Do you want to send me one of your chains so I can try it in my 2 hubs ? I will send it back. How far are you from Mansfield ? regards Paul
Philip S
Paul
I hadn't thought of that, but I suspect you are right, because I can't locate a hole when I poke around with a spoke. The hub is now with another bike shop and I am encouraging them to dismantle it. Thank you for the offer anyway. Best wishes Philip
Post Reply | |
Tweet
Forum Jump | Forum Permissions You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
