20"(451) barely used disc front wheel+tyres
Forum Name: For Sale
Forum Description: Something to sell or give away? Advertise it here
URL: http://forum.bhpc.org.uk/forum_posts.asp?TID=6978
Printed Date: 06 August 2020 at 2:30pm
Topic: 20"(451) barely used disc front wheel+tyres
Posted By: PaulM
Subject: 20"(451) barely used disc front wheel+tyres
Date Posted: 10 November 2019 at 5:52pm
Hand built 20" (ERTO 451)  front wheel, 28 spokes. Sun Ringle CR18 rim, Hope Pro 2 Evo hub. Includes 2 tyres, Velox rim tape and spare left and right spokes. Condition is used but only around 200 miles on it. Durano 28mm tyre is unused (wire bead), Schwalbe HS110 37mm tyre used for 200 miles.
This is slightly larger than the more common ERTO 406, 20" wheel, although since the radius is only 23mm greater it will often fit disc forks made for the 406 size.
£60 including UK mainland P&P.
Photos: https://photos.app.goo.gl/d47v7pUHfAoqLiNPA" rel="nofollow - https://photos.app.goo.gl/d47v7pUHfAoqLiNPA
Paul
Posted By: PaulM
Date Posted: 17 November 2019 at 11:51am
I used this on my Metabikes recumbent briefly. Can be a handy solution if you want an in-between size front wheel. It's a standard 100mm OLN hub.
Paul
Posted By: PaulM
Date Posted: 20 November 2019 at 6:24pm
Now SOLD.
Paul
