IC7 Male wrote:
Does anyone happen to know if the inner part of the boom (connected to the bottom bracket shell) is made of aluminium or steel? I'm trying to determine the likelyhood of being able to free off a seized boom on a PDQ thats for sale on ebay. Thanks, Gordon.
| The PDQ sliding boom (when not corroded ) is steel with "catlick" chrome finish The main frame is steel with painted outer and bare steel inside the tube . Pashley the makers failed to use any form of frame saver on the inside during production A few owners dealt with this by using Waxoil or similar products . So "frozen" boom tubes are now very common and a sod to sort out If yours is stuck up ??? You can soak in plus gas or wd40 for a few weeks using the drip drip messy method . Avoid hammers or mallets or pipe wrenches ….unless you plan on scrapping the PDQ Another method .,....,use a pipe freezing kit ...to crack the rust bond within If you butcher or manage to write off the boom tube assembly whilst attempting a removal ? All is not lost I have used replacements in stock along with lots of other PDQ parts such as seat frames + seat covers and steering parts + seat rubber ring doughnut shocker and more besides Plus parts for the "daddy long legs spider trike " known as the PDQ3 such as SA drum brake parts and steerer connecting rods with Q/release fittings . Just for the record …. The PDQ 3 trike folds and will pop into a Honda Jazz....you don't need a transit van ! ( Pashley often forgot to mention that when new ) So if your buying a PDQ ask the vendor if the boom slides in and out and its not a hard job to remove. Otherwise ……...buyer beware !"£$%^ Hope that helps ……..happy to advise on all things PDQ having sold them when brand new . Cheers Kevin D
------------- D.TEK HPVS purveyors of recumbent trikes and cycles
