Front calliper brake |
Post Reply ![]() |
Author | |
Coco ![]() Visitor (new) ![]() ![]() Joined: 03 August 2017 Location: Norwich Status: Offline Points: 30 |
![]() ![]() ![]() ![]() ![]() Posted: 18 October 2020 at 4:24pm |
I’ve got a Schlitter Encore with an x-eyed front calliper brake. It pulls from underneath on the left hand side of the frame. I’m trying to fit a new pair of wheels with an external rim width of 27.5mm. Unfortunately the brake will not accept rims more than 22mm. Does anybody know where I might find a replacement calliper that will take a wider rim?
JDub ![]() BHPC Member ![]() Joined: 01 November 2005 Location: Egham Status: Offline Points: 428 |
No specific help, but I have modified various brakes to work this way. Not too hard if the cable entry and anchor parts can be removed. If in the UK you might look at St John Street Cycles for a wide choice of brakes.
http://s1127.photobucket.com/user/Protobikes/library http://protobikes.org.uk/ https://www.flickr.com/photos/150386999@N02/ |
BarneyH ![]() BHPC Member ![]() ![]() Joined: 02 May 2007 Location: United Kingdom Status: Offline Points: 360 |
Not sure what size of rim they fit but I think it might be worth trying a Brompton brake:-
https://www.sjscycles.co.uk/brakes/brompton-caliper-brake-black/ |
Looks good. 8mm shaft might need drilling. Varying blocks and spacers should fit any rim. On other brakes, I filed a slot in the thread where the adjuster usually goes and put in an M6 button head screw to hold the cable. The releaser can be adapted to take an adjuster. The Dia Compes may be easiest.
Edited by JDub - 12 November 2020 at 5:37pm |
Post Reply ![]() |
Tweet
Forum Jump | Forum Permissions ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
