  New Posts New Posts RSS Feed - Front calliper brake
Coco View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coco Quote  Post ReplyReply Direct Link To This Post Topic: Front calliper brake
    Posted: 18 October 2020 at 4:24pm
I’ve got a Schlitter Encore with an x-eyed front calliper brake. It pulls from underneath on the left hand side of the frame. I’m trying to fit a new pair of wheels with an external rim width of 27.5mm. Unfortunately the brake will not accept rims more than 22mm. Does anybody know where I might find a replacement calliper that will take a wider rim?
JDub View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JDub Quote  Post ReplyReply Direct Link To This Post Posted: 12 November 2020 at 4:59pm
No specific help, but I have modified various brakes to work this way. Not too hard if the cable entry and anchor parts can be removed. If in the UK you might look at St John Street Cycles for a wide choice of brakes.
http://s1127.photobucket.com/user/Protobikes/library
http://protobikes.org.uk/
https://www.flickr.com/photos/150386999@N02/
BarneyH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BarneyH Quote  Post ReplyReply Direct Link To This Post Posted: 12 November 2020 at 5:11pm
Not sure what size of rim they fit but I think it might be worth trying a Brompton brake:-
https://www.sjscycles.co.uk/brakes/brompton-caliper-brake-black/
JDub View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JDub Quote  Post ReplyReply Direct Link To This Post Posted: 12 November 2020 at 5:21pm
Looks good. 8mm shaft might need drilling. Varying blocks and spacers should fit any rim. On other brakes, I filed a slot in the thread where the adjuster usually goes and put in an M6 button head screw to hold the cable. The releaser can be adapted to take an adjuster. The Dia Compes may be easiest.
Edited by JDub - 12 November 2020 at 5:37pm
