Ratcatcher - Broken mono front fork |
Post Reply |
Author | |
danielv
Visitor (new) Joined: 27 February 2017 Location: Windsor Status: Offline Points: 13 |
Posted: 26 March 2018 at 1:59pm |
Dear Sir/Madam Second point, one of the rear wheel bearings, in the lug at the back of the bike is grinding and needs replacing I believe. Does anyone know where to get them from? Many thanks & Regards Daniel Vinson
Daniel Vinson
GeoffBird
BHPC Member Joined: 20 September 2005 Status: Offline Points: 2397 |
Please don't weld it!
GeoffBird
I'm not completely familiar with the design, but I guess it is aluminium tubes glued into cast aluminium lugs. A steerer tube is a very highly stressed component and welding aluminium will reduce its resistance to fatigue stresses. It may not even be a grade of aluminium that is suitable for welding. The heat of welding could also cause distortion and affect other glued joints.
I would strongly recommend contacting Mike Burrows and ask his advice: 01603 721 700 WRT to bearings, www.simplybearings.co.uk are good. Either measure the existing bearings or ask Mike.
Edited by GeoffBird - 26 March 2018 at 8:27pm |
Post Reply | |
Tweet
Forum Jump | Forum Permissions You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
