Forum Home Forum Home > Public: Open to anyone > Wanted
  New Posts New Posts RSS Feed - 20" wheel[s] with 70mm SA hub brakes
 Post Reply Post Reply Page  <12
stormbird View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stormbird Quote  Post ReplyReply Direct Link To This Post Posted: 12 March 2019 at 4:02pm
It was testing after the bearings were changed that brought the problem to my attention as I have not yet ridden the wheels myself.
Can you give some idea what you consider to be ' far superior ' bearings ? and where to get them from please.
It is possible the ones I have used may only be SA quality Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote RoyMacdonald Quote  Post ReplyReply Direct Link To This Post Posted: 12 March 2019 at 6:44pm
Paul, I bought half a dozen from a bearing specialist shop on the Rochester Way. I used yellow pages to look them up, which tells you how long ago it was. I think this is them now. http://www.bearingshopuk.co.uk/ Best to ask them about which ones are high quality and they recommend for the application.
Post Options Post Options   Thanks (0) Thanks(0)   Quote stormbird Quote  Post ReplyReply Direct Link To This Post Posted: 12 March 2019 at 9:34pm
Thanks.
Paul
Post Options Post Options   Thanks (0) Thanks(0)   Quote stormbird Quote  Post ReplyReply Direct Link To This Post Posted: 13 March 2019 at 1:02pm
Kevin
As you can see I cannot use the conventional back plate mounts without extensive alteration to the rear frame ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote RoyMacdonald Quote  Post ReplyReply Direct Link To This Post Posted: 15 March 2019 at 5:27pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote stormbird Quote  Post ReplyReply Direct Link To This Post Posted: 18 March 2019 at 10:24pm
thanks will investigate
Paul
